I seem to be having issues with bleed my brakes(I've always hated the brakes on this car).
Booster is original.
All lines and hoses are new.
Calipers are remanufactured from Muskegon Brake
Master Cylinder is a new GM Restoration Parts one.
First I tried to gravity bleed with no luck, then I tried to vacuum bleed starting at the R/R with no luck.
Second, I took the master cylinder off to bench bleed it and it seemed to work. I hooked my vacuum bleeder up to the line connections on it and was able to pull fluid through so it should be okay. Then I hooked the vacuum bleeder up to the R/R caliper and with my thumb over the line where it would connect to the master cylinder I was able to pull vacuum. I also did the same to the F/R caliper and held my thumb over the front line at the master cylinder and could pull a vacuum on the front half too.
Third, I put the master cylinder back on the car and hooked the lines up and then tried to vacuum bleed it again but as before I couldn't pull any fluid from the rear reservoir.
Fourth, scratched my head , had a beer and then came in from the shop before I do something stupid and now I'm sitting here wondering if anyone has any ideas for me?
One point of interest on my bench bleeding.... as I push the piston in I get a small squirt from the front port of the front reservoir but nothing from the front port of the rear reservoir. as I release the piston there is a small "wave" of fluid from the rear port on both reservoirs. Shouldn't the front port of the rear reservoir also give a little squirt as the piston is pushed in? my four wheel disk knowledge is limited to only this car. Did I mention that I've always hated the brakes on this car??
Thanks guys.
Thanks guys.
 What's the best way to bleed the brakes on a 69?
