68 door handle - NCRS Discussion Boards
68 door handle
  • James H.
    • February 22, 2007
    • 130
    68 door handle
    Is there an easy fix for this door handle that is sticking up past flush? I'm not going to replace them at this point.
    thanks..
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 68 door handle
    James it has been over 20 years since I have had my 68's door panel off, so cannot remember how well you can see the bottom of your door handle when the door panel is removed. If I remember correctly there is a "stop" for the upward lift of the handle. Again, going from memory, I took a stainless steel tip that covered the eraser of mechanical lead pencil and slipped it on the door handle's "stop". This adjusted the "stop".
    • Richard D.
      • December 1, 2002
      • 328
      Re: 68 door handle
      thanks..
      I used a length of stainless steel wire to create a "stop" to prevent the handle portion from coming up as far due to wear slop created over the years. It actually worked.
      If you need a pic of this, email me at rwmnc@optonline.net and I will take a pic of what I did and send it to you. Tough to get the idea with words alone I would think. Rich
