Burning T-3's - NCRS Discussion Boards
Burning T-3's
  • Steve M.
    • October 22, 2006
    • 88
    Burning T-3's
    I am trying to put some finishing touches on the 67 before the Heartland Regional in a couple of weeks and for some reason, maybe bad luck, the low/high bulb on the drivers side keeps burning out. I have all new harnesses and so far in the past couple of weeks I have gone through 2 original T-3s and one Lectric Limited repop. All of the other lights work and the bulbs that burn out work on high beam. Is this just a case of bad luck with some old bulbs and a repop or has anyone else had this problem and found a solution. I must say it makes me a little nervous about the operations test. They seem to work about 3 or 4 times when I check them and then gone!! Any ideas to check? Thanks
  • Bill I.
    • January 29, 2008
    • 554
    Re: Burning T-3's
    When you changed them, did you check to see if they are really burned out? Think you can see where I'm going here, bad or loose connection. ill
    • Stephen L.
      • May 31, 1984
      • 3156
      Re: Burning T-3's
      It appears to be a stroke of bad luck to me. The voltage can't be excessive (due to an improperly set regulator) because then other lights would also burnout.
      Do you possibly have a faulty/intermittent connection at that location or a broken wire in the harness that causes the light to stop working? I assume you checked the "burned" lights to make sure they are indeed burned out on the low beam and you don't have a faulty harness?
      • Steve M.
        • October 22, 2006
        • 88
        Re: Burning T-3's
        Thanks, I did check to make sure they were burned out and that the connections are good.
        • Bill I.
          • January 29, 2008
          • 554
          Re: Burning T-3's
          Steve, guess you have to chalk it up to old age and cheap China crap. Bill
          • Harmon C.
            • August 31, 1994
            • 3228
            Re: Burning T-3's
            When bulbs smoke and burn they turn white or test them. Any bulb that has been droped in shiping may burn out when installed. I had a case of bulbs fall about two feet and most of them smoked and burned.
            Lyle
            • Alan D.
              • August 31, 2000
              • 111
              Re: Burning T-3's
              I believe as the bulb ages the seals around the connection tabs begin to deteriorate. This allows oxygen to enter into the lamp causing the element to burn out. Anytime I buy a lamp I seal around the connection tabs with silicon sealer. This will help prevent future deterioration of the seal and create an additional seal. It seams to work for me.
              Al Dieterle
              • Steve M.
                • October 22, 2006
                • 88
                Re: Burning T-3's
                Good suggestion Alan, thanks.
