Welding crack in 58 FI exhaust manifold - NCRS Discussion Boards
  • John N.
    • February 1, 1975
    • 451
    Is there a good shop for welding a crack in a 58 FI exhaust manifold? Is it worth doing?
  • Loren L.
    • April 30, 1976
    • 4104
    Re: Welding crack in 58 FI exhaust manifold
    John, Big Mike Scott in CA used to have a fellow who was excellent.
    • John N.
      • February 1, 1975
      • 451
      Loren, thanks. Do you have Mikes current numbers?
      Regards
      • Mike M.
        • May 31, 1974
        • 8383
        dean at cresap machine in cumberland has done a bunch for me. 301` 724 8794. tell him we're buds. he'll weld but you will have to grind and dress it. mike
        • Jim D.
          • 2884
          Any shop that rebuilds/repairs engine blocks can do it. The key is pre-heating before welding.
          • Steven B.
            • June 30, 1982
            • 3990
            John, in the distant past I had an aircraft shop weld an exhaust manifold and they did a very good job. There should be at least on one near any large city.
            Good Luck,
            Steve
            • Craig B.
              • June 30, 2000
              • 14
              John, most proficient welders can weld cast iron, the problem is that they use stainless steel rod or braze it. Neither process will pass muster on the judging field and may produce more cracking when used. The process that I have only seen the results of, requires preheating the part to over 900 degrees f, welding, preheating again, and repeating the process until the weld is completed using cast iron rod. The only people that I know of to use this process are located at www.jaylenogarage.com or you may find a welding service specialising in this work in Hemmings Magazine. Finally, I have only heard of this processed used on very rare (also expensive) parts, and almost always heads or blocks.
              • Joseph K.
                • August 26, 2008
                • 407
                Here is a link to the site that may be a help
                LOCK-N-STITCH Inc. provides cast iron repair services such as metal stitching, emergency thread repair, fusion welding, & machining services for industries in power generation, gas compression, shipping, and pumps.
