C1 Radiator Support Seal Installation - NCRS Discussion Boards
  • Joe P.
    • October 4, 2007
    • 209
    Need some help.. I am about to install a new DeWitt Aluminum rad and wanted to install he suppoert seals, but i can figure out where the lower radiator support seals are placed .. appreciate any pics or directions.
    Thanks..
    Joe
  • Dennis C.
    • June 30, 2002
    • 883
    Re: C1 Radiator Support Seal Installation
    [quote=Joe Plati (47952);487110]Need some help.. I am about to install a new DeWitt Aluminum rad and wanted to install he suppoert seals, but i can figure out where the lower radiator support seals are placed .. appreciate any pics or directions.
    Thanks..
    Joe
    [/quote
    Joe,
    The two short pieces are for the lower corners around the X bracing. The long piece is for the bottom. They seal the radiator frame to the body. I have some pictures but I am not home. If no one posts a picture and you still need a picture, let me know and I can post it tomorrow night.
    Dennis
    • Joe P.
      • October 4, 2007
      • 209
      [quote=Dennis Crupi (38211);487168]
      Thanks..
      Joe
      [/quote
      Joe,
      Dennis
      Dennis, can you forward the pics.. Thanks.
      • Dennis C.
        • June 30, 2002
        • 883
        Joe,
        Hope these help.
        Dennis
        • Joe P.
          • October 4, 2007
          • 209
          Thanks Dennis..
          How are they held on?
          Joe
          • Dennis C.
            • June 30, 2002
            • 883
            Thanks Dennis..
            Joe
            Joe,
            The AIM calls out for "cement". I would think most would use weatherstrip adhesive or maybe contact cement. If weatherstrip adhesive is applied according to the installation directions, it should be just fine.
            To properly use weatherstrip adhesive, both surfaces need to be cleaned with the proper solvent, the adhesive applied to both surfaces and allowed to tack over, and then additional weatherstrip adhesive is applied to one surface. The parts are then held together.
            This method produces a very strong bond.
            Dennis
            • Joe P.
              • October 4, 2007
              • 209
              Originally posted by Dennis Crupi (38211)
              Joe,
              Dennis
              Dennis, Thankyou very much, greatly appreciated. I searched my AIM and didnt see it ..
              Joe
