ID'ing a muncie tag 70? - NCRS Discussion Boards
  • Dennis D.
    • March 1, 2000
    • 1071
    Trying to help someone out with his 70. Waiting on the vin code case numbers, but thought the tag might help
    main casting 3925661
    side cover 3952648
    tailhousing 38575846m
    Tag # 3932659wb
  • Eric D.
    • February 1, 1992
    • 42
    Re: ID'ing a muncie tag 70?
    Tag decodes as 1970 M-20 passenger side speedo, 8 tooth speedo gear on main shaft... Hope this helps... Crash
    • Dennis D.
      • March 1, 2000
      • 1071
      thanks it does
      • Wayne M.
        • March 1, 1980
        • 6414
        side cover 3952648
        Tag # 3932659wb
        A bit more to add to Eric D's reply: the tail # ends in ...584. The '6' is really a letter 'G' to go with the 'M'.
        Also mis-read on the tag: third number is probably a '5' (not a 3), and indicates a wide ratio 4-sp. for 1970.
