1964 Corvette steering column - NCRS Discussion Boards
  • Robert K.
    • November 17, 2009
    • 64
    Does anyone know if there is supposed to be a screw or bolt on the side, in the rear, of the steering column housing, opposite the blinker; to secure the housing? Hope I explained this correctly.
  • Dan H.
    • July 31, 1977
    • 1372
    Re: 1964 Corvette steering column
    Only on 63 columns, not 64, check the 64 AIM for details.
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • Robert K.
      • November 17, 2009
      • 64
      no details in the shop manual?
        The screw hole was for the "wedge", which was only used in 1963 to secure the bowl; the wedge was eliminated for 1964, but they didn't modify the mold for the bowl and left the screw hole in it. The hole is there, but it isn't used.
        • Robert K.
          • November 17, 2009
          • 64
          John,
          Do you know id there is a way to tighten the bowl? It apprears to be a little loose and wiggles?
            John,
            The bowl is secured to the column jacket by a circular stamped sheet metal retainer with slots that engage the tabs at the top end of the jacket; the screws that attach the turn signal switch secure the retainer to the inside of the bowl. Make sure none of the three tabs are broken off.
            See your Assembly Manual, UPC 12, sheet C1.00 - it shows the installation.
