Correct spark plug - NCRS Discussion Boards
Correct spark plug
  • Gary G.
    • March 1, 2001
    • 47
    Correct spark plug
    I have a question regarding the 75 L 48 engine. I currently use the R44TX plug, which is for the HEI ignition. What plug is one range hotter? Some people locally told me that the R44TX is obsolete, is this so? I still see it listed in many AC catalogs. If it is not available, what plug can be substituted?
    Thank you for any information.
    • 43221
    Re: Correct spark plug
    Gary-----
    The AC R44TX is the correct spark plug for your application. It is also known as GM #5613869. It's no longer available through the GM parts system but it is available through the Delco parts system.
    Want one range hotter? No problem. Use an R45TX, aka GM #5614252.
    • Gary G.
      • March 1, 2001
      • 47
      Thank you Joe.
