Screeching noise source identified - NCRS Discussion Boards
  • Steve D.
    • February 1, 2002
    • 990
    Following suggestions from a recent post, I identified the source of the screeching noise during revving as the NEW fan clutch. Is there any way to quiet a screeching clutch?
    Steve
  • Loren L.
    • April 30, 1976
    • 4104
    Re: Screeching noise source identified
    Yes, send it back to the seller and ask for PLan B - where he sends you another or your $$$ (and core?) back.
      • 43221
      Steve
      Steve------
      Is this a GM #3916141 Eaton-manufactured clutch?
      • Steve D.
        • February 1, 2002
        • 990
        Joe
        I'll check the PN when I get in this evening.
        • Steve D.
          • February 1, 2002
          • 990
          Joe
          The only identifying marks on the clutch are on the forward facing face and they are a) an arrow point in a clockwise direction and b) the numbers 27110050. I bought it from Corvette Central sometime back when I was assembling the engine.
            • 43221
            Joe
            Steve------
            Can you post photos of it?
            • Steve D.
              • February 1, 2002
              • 990
              Joe
              First attempt to attach a photo. It apears to have uploaded, so here goes.
                • 43221
                Joe
                Steve------
                This is definitely not the GM #3916141, I don't even know if it's an Eaton-manufactured piece. It may be a Hayden, Four Seasons, or some other aftermarket brand. It could even be a Delco part but, if so, just an aftermarket-type piece in a Delco box. It is a thermostatically-controlled unit as opposed to a real "el cheapo" non-thermostatic type.
                I'd say you got a defective piece, though. Quality is less certain with a part like this, but it should not screech. If you're sure the screech is caused by the clutch, I'd say return it.
                • Michael W.
                  • April 1, 1997
                  • 4290
                  How did you differentiate the sound coming from the clutch vs. a loose/slipping belt?
                  • Steve D.
                    • February 1, 2002
                    • 990
                    The noise stopped after I removed the fan and reinstalled the pulley and belt.
                    • Michael W.
                      • April 1, 1997
                      • 4290
                      The load from the fan might cause the belt to slip. Been there, done that. New fan belts are cheap and are good to keep as spares anyway.
                      • Steve D.
                        • February 1, 2002
                        • 990
                        I thought about that, but the noise really sounds metallic. The belt is new, but I'll try another one to be sure.
                        • Tom L.
                          • October 17, 2006
                          • 1439
                          I went through a very similar problem with my '72 BB w/ a/c. Does your car have a captive belt and it it in place? I went through the same procedure you are going through and almost bought a new fan clutch but re-considered.
                          Turned out that my problem was that the captive belt was not installed, I didn't take it off but didn't do anything about it. Many told me it wasn't needed. Perhaps on non-a/c cars it may be the case but the big 7 blade fan used with a/c cars was too much of a load on the single belt on the water pump pulley. Once I realized that I HAD to put the captive belt on the problem went away. Good luck!!!
                          • Stuart F.
                            • August 31, 1996
                            • 4676
                            By captive belt, do you mean a separate belt running between the crank pulley and the water pump pulley which would use an idler pulley to provide adjustment? Otherwise, not sure what a "captive belt" is.
                            Stu Fox
                              • 43221
                              Stu Fox
                              Stu------
                              A captive belt is one that runs between the water pump and crank pullies with or without an idler pulley. As a matter of fact, in the truest sense, it's a belt that runs between these two pullies with NO idler for adjustment. MANY Corvettes from about 1966 onward used a captive belt.
