Clutch Recommendations? - NCRS Discussion Boards
  • Patrick N.
    • March 10, 2008
    • 954
    I am in the home stretch to drop my motor back on the frame and need to buy a clutch-could use some recommendations on what clutch I should look for or consider. I would like a car that drivable with a clutch that is not grabby?
    The car is a 68 427/400HP (The cylinders were bored a bit over during the rebuild so it will push a little more hP, Trans is an M20 with 3:08 rear).
    Any thoughts or POV are welcome.
    thanks
    pat
  • Larry M.
    • January 1, 1992
    • 2700
    Re: Clutch Recommendations?
    Pat:
    The archives are full of info on this subject.....but the summary is a LUK Rep Set or a Centerforce II. Both have excellent reviews.
    A few others prefer the Hays Street Clutch, but this is more $$$ for not much (if any) benefit.
    Be certain you have the correct size disc and pressure plate. I think for your car it is the 11 inch. Resurface and balance the flywheel and the new pressure plate assembly. Install a new Oil-lite type pilot bushing. Also, you want to be certain that the pressure plate is a diaphram-type, and that the throw-out bearing is the correct length. Archives has all this info.
    Larry
      • 6948
      Pat, the Luk clutch as larry rec. is good all around for a street driven car, some time the performance clutches have alittle more spring tension on the pressure plate.
      • Patrick N.
        • March 10, 2008
        • 954
        thanks Larry-youre right, I'll dig through the archives as well. thanks for the info you provided.
        Pat
        • Dick W.
          • 10483
          Be sure and surface the flywheel.
          Dick Whittington
