273445 Screw-Pan Head Cross Recess Tapping - NCRS Discussion Boards
  • Chris H.
    • April 30, 1990
    • 817
    273446 Screw-Pan Head Cross Recess Tapping
  • Timothy B.
    • April 30, 1983
    • 5196
    Re: 273445 Screw-Pan Head Cross Recess Tapping
    Chris,
    Is this the screw for the ballast resistor??
    • Chris H.
      • April 30, 1990
      • 817
      Re: 273446 Screw-Pan Head Cross Recess Tapping
      First, sorry I mistyped the part number. 273446 is the correct one.
      2nd, not sure on usage but check the AIM for your vehicle. I know it was used somewhere on my 62 because that is the reason I pulled it from the CEC file room many years ago. As I restored my 62 back then I would pull questioned drawings from the file room which was next to my office.
      I have a lot of drawings and decided to start posting them here for everyone to be able to use.
      • Dick W.
        • 10483
        McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
        Dick Whittington
        • Dick W.
          • 10483
          You can check Fastenal, McMaster Carr, or Auveco for most screws. If they are not in one of the catalogs, chances are that they are not being made anymore
          Dick Whittington
          • Rod K.
            • 443
            Originally posted by Timothy Barbieri (6542)
            Chris,
            What year? According to catalogs 55-60 should be a clutch drive, 61-62 a cross recess. At any rate, the 273445 #8 x 3/8 and 273446 #10 x 1/2 are used many places to join body panels. The ballast screw is a # 12.
