Grease and heat - NCRS Discussion Boards
Grease and heat
+ More Options
Posts
  • Ray C.
    • June 30, 2001
    • 1132
    Grease and heat
    The heat from the crossover exhaust pipe on my 270-HP engine is heating the chassis grease from the inner ball-joints and causing it to break down into oil viscosity and dripping on to the floor. Have others had this problem and how did you rectify this problem?
    Thanks for any information!
    Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • Terry D.
    • May 31, 1987
    • 2697
    Re: Grease and heat
    Ray
    Do you have an IR gun to check just how hot they are getting? Never had this particular problem. Have you check timing etc to be sure everything is as it should be? Is the choke opening as it should? That pipe should cool down after choke opens all the way.
