65 Window Fit Into Soft Top Weather Strips - NCRS Discussion Boards
  • Mark F.
    • June 30, 1995
    • 60
    I am preparing my 65 fuel car for PV. It's pretty much and original car is great shape, except for the soft top weather strips, which were ready for retirement.
    I have purchased and installed a new soft top weather strip kit. I am perplexed, however as to what the correct fitment is for the two side windows relative to the weather strips they contact, that is, where the the top edges of the window glass and rear vertical edges of the glass mate with the corresponding weather strips.
    The soft top weather strips that mate with the side windows have a channel in them. On the inboard side of the channel, there is a larger, more robust piece of rubber. On the outboard side of the channel, there is a smaller, thinner "flap".
    If the door is open and the window glass is fully rolled up and then the door is subsequently closed, the window glass then squishes this outboard flap into the weather strip channel, with the window glass now outboard of this flap. Here is my question. If the window is subsequently rolled down while the door is still closed, and then rolled back up, is the window glass then supposed to fit into the weather strip channel such that the outboard flap of the weather strip is now outboard of the window glass?
    I hope this question makes sense to someone!
    Thanks!
  • Lynn H.
    • December 1, 1996
    • 514
    Re: 65 Window Fit Into Soft Top Weather Strips
    Mark,
    Have you looked in the AIM (assembly instruction manual)? Looking in my 65 AIM (upc1, F9, pg.-E85 in mine) they show the installation of the side rail weather strips with a cross section of the window and how it SHOULD fit in the weatherstrip. Installed correctly it should not matter if the window is up, or down when you close the door, and the window should seat in the weather strip as shown.
    Lynn
    • Mark F.
      • June 30, 1995
      • 60
      Originally posted by Lynn Houk (28522)
      Mark,
      Lynn
      Thanks Lynn
      I attached a photo of my window closed, but not sure if the photo is to big.
