Engine quits cont'd_problem solved - NCRS Discussion Boards
  • Steve D.
    • February 1, 2002
    • 990
    On 4-19 I posted a problem of the engine quitting suddenly after warm up of approximately 15 mins. I checked my grounds, checked the plug wires, and plugged the heat x-over in the intake manifold; all to no avail. Then, as Mr. Barbieri suggested, I removed my NEW coil and replaced it. Started, warmed up and ran at idle for 20 mins: no shut down. Went to get gas and took the long way home with no problems. Just to make sure, I let the engine cool, then re-installed the offending coil and repeated the idle routine. Sure enough after about 12 mins. the engine quit. Now I need to dig up the receipt for the coil.
    Thanks everyone.
    It was a good exercise, because I had been intending for a good while to block the heat x-over.
  • Timothy B.
    • April 30, 1983
    • 5193
    Re: Engine quits cont'd_problem solved
    Steve,
    I am glad you got the car straightened out. Your car is the second that I know of that's had this coil problem with reproduction coils. If you need a good coil, go to NAPA or watch ebay for a 1115202. I bought one for my car in the pull string box for 125. Worth the money considering what you went through..
    Thanks for posting the results.
    • Tom H.
      • December 1, 1993
      • 3440
      Good call, Tim.
      Tom Hendricks
      Proud Member NCRS #23758
      NCM Founding Member # 1143
