Which 1107365 starter date should I use? - NCRS Discussion Boards
  • Larry T.
    • May 15, 2007
    • 404
    I am about to send a 1107365 big block starter off to be restored. I have two dated as follows:
    September 20, 1965
    October 18, 1965
    The car is a November 5th car and the engine assembly date is October 6, 1965.
    Which starter should I use? Thanks.
    Re: Which 1107365 starter date should I use?
    September 20, 1965
    October 18, 1965
    Larry -
    I'd use the October 18th starter; the starter was installed at St. Louis, so it relates to the car's final assembly date, not to the engine assembly date.
    • Larry T.
      • May 15, 2007
      • 404
      I figured I could get away with either, but that was my best guess too. I wanted to be sure it was not too late (close to production) a date.
      Larry
      • Ronald L.
        • October 18, 2009
        • 3248
        Larry, all those original parts on my car have dates one to three weeks ahead of the body asy. Oct date is right where you want to be.
        • Michael G.
          • January 1, 1997
          • 1251
          Build date of engine should be taken into consideration as starter would need to be manufactured before build date of engine.
          • Larry T.
            • May 15, 2007
            • 404
            Michael,
            Are you certain? If the engine was assembled in Tonawanda on October 6 without the starter, and shipped to St. Louis where a starter was added and the complete engine was installed in a car the first week of November why would a mid October starter not work?
            • Ronald L.
              • October 18, 2009
              • 3248
              Larry, your Oct 66 is earlier than a 12/13 66 427 I once owned or the current April 427.
              The date spread was the same, this car has all those original guts.
              4-28 body - car
              4-20 alt
              4-13 starter
              this list goes on...
                Mike -
                Nope. The engine build date has no relationship to the starter; the starter was installed at St. Louis, not at the engine plant.
                • Michael G.
                  • January 1, 1997
                  • 1251
                  Thanks for the heads up John.....always learning.
                  • Larry T.
                    • May 15, 2007
                    • 404
                    Mike -
                    John,
                    Can you give a real quick rundown on what was on the engines as they came out of Tonawanda? Oil pan? Valve covers? Water pump? Intake?
                    Thanks.
                      John,
                      Thanks.
                      Larry -
                      Intake with thermostat housing and throttle return spring bracket, valve covers, distributor, water pump, oil pan, flywheel/clutch/bellhousing and lower inspection cover, harmonic damper, and spark plugs.
                      All engine parts in the Assembly Manual shown with an item number and part number callout were installed at St. Louis; any engine parts illustrated without a part number callout came as part of the engine assembly.
                      • F S.
                        Infrequent User
                        • January 1, 1981
                        • 28
                        I have a starter # 1107 365 dated 5 E 21 . I was going to use it in my 396 65 Corvette. Is the 365 correct for a 1965 BB ?
                          • 43219
                          F.W.------
                          No, it's not correct for a 1965 L-78 despite the fact that the date "would work" for some 1965 L-78's. 1965 L-78 used starter GM #1107352. This is a VERY difficult-to-find starter part number (although a functionally equivalent and "identical-except-for-part number" starter would be very easy to obtain).
                          Assuming that the 1107365 starter you have is as originally configured (which may not be the case if it's been through a high volume commercial rebuilder), it would not even work for a 1965 L-78. 1965 L-78 used a starter with an aluminum nose with short and long starter bolts used with 12-3/4" flywheels. The 1107365 starter as originally configured used a cast iron nose with 2 intermediate length starter bolts for 14" flywheels.
                          • F S.
                            Infrequent User
                            • January 1, 1981
                            • 28
                            Joe, thank you for the information. It does confirm my information. The nose cone doesn't fit into the fly wheel,either. I have learned that the nose cone is specific to the L-78 motor.
                              • 43219
                              FW-----
                              The starter nose is by no means unique to the L-78. It's basically the same for all engines with 12-3/4" flywheel, big block and small block alike.
