70 alternator connections hardware - NCRS Discussion Boards
+ More Options
Posts
  • Bill L.
    • February 1, 2004
    • 1403
    I have an elastic stop nut/vibration proof nut for the positive connection. Does this sound like the correct nut? It was the nut I removed. However, the alternator had been changed.
    Does the thin screw for the negative connection have any head marking?
    I am installing the restored original alternator.
    Thanks! Bill
    • 43263
    Re: 70 alternator connections hardware
    Thanks! Bill
    Bill------
    The nut used for the alternator positive connection was a #12-24, 5/32" thick standard hex nut of GM #284M material grade and zinc plated. The lockwasher, which installs under the terminal, is an external tooth star washer.
