Bought one of those nylon threaded hex fittings with a grease nipple on top (off eBay). Included directions say to remove forward steering box cover bolt, screw in nylon fitting, remove REAR cover bolt; fill until grease starts to exit rear bolt hole.
I'm thinking that by doing this, there would be no air pocket for lube expansion, and I had a bad experience with my '63 twenty years ago, where the garage blew out the plug at the front end of the gear box.
I notice that the '65 owners guide says forward and OUTBOARD bolts (ie. don't touch the rear bolt [nearest the firewall]). The '63 Corvette Shop Manual says forward and INBOARD ?? bolts.
Do we all agree it should be forward (grease in); outboard (air out, until grease seen) ?
in there, and maybe next winter do an R&R.
