68 wireing help - NCRS Discussion Boards
68 wireing help
  • Alan B.
    Infrequent User
    • November 1, 1999
    • 4
    68 wireing help
    Need help with wireing on early 68. New wiring for dash. Center gage wireing in question. Have brown wire with single plug, where does it go ? Have black wire with ring terminal, assume it is ground, where does it go ? Is their a wire that goes on post of seat belt warning circuit board ? Thanks, trying to make Gettysburg.
    • 6960
    Re: 68 wireing help
    Alan, the brown wire is it long enough to go on the e/brake switch and there is ground on the center console piece around the ash tray area, and take a look at the gage cluster I believe theres one there, the eyelet not maybe correct, there both spad connects as I recall.
    • Alan B.
      Infrequent User
      • November 1, 1999
      • 4
      Re: 68 wireing help
      Thanks for answering, the brown wire is dark brown and is short, only can go some where on gage or tack. The e-brake wire is tan and is connected already.
        • 6960
        Re: 68 wireing help
        Alan, looking at the wiring diagram, the is a brown wire on the ing. switch is there a spad connector there? Thats not to far from the console.
        Alan send me your e/mail and I will send you a diagram I found on internet.
        • Alan B.
          Infrequent User
          • November 1, 1999
          • 4
          Re: 68 wireing help
          email alan_borgstrom@tnb.com
            • 6960
            Re: 68 wireing help
            Alan sent you a email, let me know if you got it.
