WCFB question - NCRS Discussion Boards
WCFB question
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12883
    WCFB question
    Hi all,
    I noticed last Saturday that one of the two little injectors in the WCFB of my '59 base engine which spray some extra gas in the front two barrels when I engage the gas pedal is blocked. Can I get these injectors out (by unscrewing the little bolt which holds them) without further dismantled the carb so I can blow some air through them to remove the blockage? Obviously I will attempt not to drop any part into the barrel openings!
    regards,
    Rob.
    Rob.
    NCRS Software Developer
  • John L.
    • February 20, 2009
    • 186
    Re: WCFB question
    Rob:
    Take the carb off. Even if you could get the screw out without removing the carb top cover,... there's a check valve under that nozzel that will end up in your engine!
