Hand written entry on 68 tank sticker - NCRS Discussion Boards
  • James H.
    • February 22, 2007
    • 130
    I have both,the tank sticker and build sheet from my 68 roadster that I found under the drivers side carpet. The last option is "hand written" in blue ink.
    "Option No 02P01AA Wheel covers"
    Has anyone else seen this and what does it mean?? I can e-mails pics to someone, I haven't had luck posting pics. My VIN is #320
    Jim
  • Tom H.
    • December 1, 1993
    • 3440
    Re: Hand written entry on 68 tank sticker
    I'm no expert on what went on in the plant back then, but I'd say the option code was added to your car after the sheet was printed. maybe a last minute customer/dealer/zone request.
    Was your car built with wheel covers, as far as you know ??
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • James H.
      • February 22, 2007
      • 130
      Tom,I purchased the car 2 yrs ago after sitting idle for 20 plus years and it did have the P01s on the car. It also had hand written on bottom of both copies..
      RN00 with the initials JW
      • James H.
        • February 22, 2007
        • 130
        The other thing that is odd is my car has a set of 67 rallies.. DC codes i believe. 6in. wide, not 7in.
        I removed them and going to put them on my 67.
        • Tom H.
          • December 1, 1993
          • 3440
          Now that would seem odd. What is build date of your car ???
          Tom Hendricks
          • James H.
            • February 22, 2007
            • 130
            The area on top of my build sheet that reads "date recieved" is 07-27-68 the vin number is #320 so its a very early 68.
            • Jim T.
              • March 1, 1993
              • 5351
              Maybe there is a 67 out there with your 68's wheels. Is your spare the correct for your 68?
              • Harry S.
                • July 31, 2002
                • 5305
                James, maybe I'm wrong but the build sheet was produced prior to the VIN being known, so I'm not sure your looking at a build sheet.
                Give it another try and post pictures of both documents.
                • James H.
                  • February 22, 2007
                  • 130
                  no spare on car..
                  Still struggling with pics.. file continues to be too big. resized down to 800x600 and still way too large.
                  • Tom H.
                    • December 1, 1993
                    • 3440
                    James:
                    Try to email me your pic. I will try to post it for you.
                    ratmotor@bright.net
                    Tom Hendricks
                    • William L.
                      • December 1, 1988
                      • 944
                      What am I missing here??? 07-27-68 wouldn't that be near the end of the 68 model run?? If the vin is 320 it would have been built in Sept of 1967.
                      Or am I missing something?
                      Bill Lacy
                      1998 Indy Pacecar
                      • Wayne M.
                        • March 1, 1980
                        • 6414
                        no spare on car..
                        Just a thought; the documents you want to post are in portrait orientation (height > width). Unfortunately, this DB is quite restrictive; not only does it limit jpeg file size to 293 kb, but also demands that the limiting dimension be the lesser of or equal to 800 (wide) and 600 (high).
                        I don't know if this is the problem but it took me a while to figure it out.
                          Jim -
                          Any time a change or substitution was made to the specs on the original order after the car's paperwork was printed (which was before the VIN was assigned), you'll find the hand-written "RN number" and intials; that revision authorized the change and corrected the plant's inventory records to recognize the material change.
                          • James H.
                            • February 22, 2007
                            • 130
                            You've got a good point there with the dates.. i guess I dont understand what that "recieved date means" I was thinking it was July of 67.. and vin is 00320..
                            The other entry next to it is "exp date of prod. 09-29-67"
                            • Mark D.
                              • June 30, 1988
                              • 2152
                              Jim's paperwork...I'll have another one in a minute.
                              Kramden
