How do fan clutches fail?
Re: How do fan clutches fail?
Joe,
Out of hundreds of pictures, this is the only one that I can find that shows any of the fan clutch...this was taken right after I get the motor in and running last year. Let me know if it shows anything...
Thanks,Attached Files- Top
Tommy------
Yes, it shows everything I need to see. What you have here is a GM #343721. This fan clutch was used for 1974-75 Corvettes with C-60. It was also used for many 76-81 Corvettes with C-60 and/or HD cooling.
The 343721 is noisy. Or, I should say, when you have one installed on your car the fan makes a lot of noise. That's because this clutch stays engaged a lot more and, thus, the fan pulls a lot more air a lot more of the time. This is a good thing notwithstanding the noise created.
I absolutely LOVE the 343721 and its nearly identical successors. It's the best fan clutch ever installed on a Corvette. Period. The extra sound a fan makes when this fan clutch is installed is "music to my ears".In Appreciation of John Hinckley- Top
The only two I know are Fred Olivia, and Vinny at Pampered Vettes.
Fred is the most well-known, but typically has 6 months + turnaround time. Outstanding work
I have also heard good reports about Vinny, including excellent work and quick turnaround. He often advertises in the Driveline.
Phone numbers for both are listed in the archives....just search. Or let me know and I will go through my files for you.
Larry- Top
duke,
Lifted directly from the Eaton part drawing...not sure on the specific usage for this clutch maybe joe can help..- Top
My '77 vintage P&A catalog shows 3916141 for 60-67 except 427, so this is probably "tuned" for a 180 degree thermostat and the ...141 is probably an "assembly" consisting of the ...139 and something else.
Duke- Top
John------
As far as original applications are concerned, the GM #3916141 was used as follows:
L1967 passenger car with 6 cyl and C-60
L1967 passenger car with 396 and 427
L1967 Chevelle with 396
L1967-68 Chevy II with 327 and C-60
L1967 Camaro with 396
E1968 Corvettes with L-36, L-71 w/o C-60
1968-69 Corvettes with L88 or ZL1
The 3916141 eventually replaced for SERVICE all 1960-70 Corvette fan clutches as well as most 1960-68 fan clutches used for other Chevrolet models.In Appreciation of John Hinckley- Top
Duke------
The GM #3916139 is a fan clutch originally used for Corvette small blocks in the L1967-69 period. It has a slightly longer shaft than the 3916141. I do not know if there exist other "calibration" differences from the 3916141.
The 3916141 eventually became SERVICE for Corvette small blocks, but it was not originally used for Corvette small blocks. However, it was originally used for some small block applications in other Chevrolet cars.In Appreciation of John Hinckley- Top
The 3916139 drawing shows the coil type thermostat in the front of the fan clutch. The distance form the water pump mouting surface to the fan surface is 1.80 inches. The drawing for 3814560 shows the bar type clutch with the exact same performance curve and the distance is 1.85"- Top
Larry
Fred has had my original '69 427 fan clutch for a year now. It too had a noticable wobble in the shaft. I am waiting with great anticipation for the day it can become reunited with my car, as I am using a loaner. I have heard it said that patience is a virtue.- Top
Tommy------
Thanks for the information Joe...I guess a little "music" is better than the overheating alternative!- Top
