Hey all ...
I am doing the following and need some help....
I purchased a Holley 6210 650 spread-bore replacement for the QuadraJet.
I want to use the Holley for driving/daily use and keep the 7042217 for NCRS shows only.
I have the carb mounted and running - no issues there.
I can not use my stock dual snorkel air-cleaner, it sits to high and the breather plumbing (bent tube from air-cleaner) hits the accelerator pump lever on the secondaries.
I ordered an air-cleaner kit/assembly from Paragon, but ordered the kit for 66/67 BB application. I did this hoping that the base would have the correct drop and elbow/tube fit necessary. Plus the 425HP 427 used a big ass Holley and it fits under it okay.
Does anyone see any issues with this?
Should I have ordered the 68/69 427 kit instead?
ANY INSIGHT is really appreciated with this!!
