Dipstick buttons - NCRS Discussion Boards
Dipstick buttons
  • D S.
    • March 1, 2005
    • 1551
    Dipstick buttons
    What company or companies manufactures those reproduction oil dipsticks? Does any company supply the plastic buttons on the handles of the dipsticks? In many cases Corvette owners and I'm sure other Chevrolet owners have lost the plastic buttons from their oil dipsticks. Engine compartment heat often is the culprit. I'm thinking maybe one can get the correct size red or black or whatever color buttons to replace them. But where?
    Scott Sims
    Texas Chapter
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: Dipstick buttons
    I never seen them new but a yard picker may have a few.
    Lyle
    • D S.
      • March 1, 2005
      • 1551
      Lyle, I was thinking a red, round swizzle stick. Never saw them in other colors. To read eBay color descriptions they came with several colors of buttons.
      The buttons appear to measure around 1/4" wide. I just need to find plastic rods in various colors in that size.
        • 43273
        Scott------
        I think the buttons have a "step" on them so as to fit into the tubular loop and "seat" on the end of the tube. If so, a piece of plastic "rod" (of equal OD from end-to-end), will not work properly.
        • D S.
          • March 1, 2005
          • 1551
          Scott------
          I think you are right about that, Joe. I believe that the button part that is inserted ino the handle can be swaged down before inserting. I don't know the depth nor what holds it in. Pressure? Glue? But for those of us who have lost or heat distorted buttons there has got to be a solution. Mine is a MIA black.
            • 43273
            Scott------
            I think they are just an interference fit. I doubt that GM was concerned if the buttons had long-term durability. I think the primary purpose of the buttons was for quick, assembly-line identification of the correct dipstick for an application.
            • Jean C.
              • June 30, 2003
              • 688
              Scott, if you can find a solid or tubular piece of plastic of the correct color, I would think that perhaps a bit of drilling followed by some file work and finally a drop or two of super glue, you would be in business. Who knows, you might begin a cottage industry making dipstick buttons in various colors .
              Best regards,
              • Steven G.
                • November 17, 2008
                • 348
                Scott, I measured the depth inserted into tube from a sheared off black tip, 70', L-46, 7/16", and being hollow like a tube made the measurement possible. Steve
                • Joseph M.
                  • June 30, 1999
                  • 334
                  Zip makes a dipstick repair kit that contains a black button. The part no# is M-3626 and sells for 10.50. Their order line is 1-800-962-9632. Hope this helps.
