Convertible decklid question - NCRS Discussion Boards
  • Chris E.
    • November 3, 2006
    • 1335
    When you open the convertible top decklid, just underneath the fixed part of the rear deck is a support bar. This bar runs side to side on the car between the towers for the springs that hold the decklid in the up position.
    My question is about that bar.
    What finish should it be?
    Here is the bar in question.
    Chris Enstrom
    2011 Z06, red/red
  • Joe R.
    • May 31, 2006
    • 1822
    Re: Convertible decklid question
    Chris,
    Did you mean to attach a picture?
    Joe
    • Tim E.
      • April 1, 1993
      • 360
      Chris - Here are 2 photos of my '66 prior to restoration that I think will help you. The only paint is body color overspray. Tim
      • Chris E.
        • November 3, 2006
        • 1335
        Tim, thanks. That looks like mine.
        I was hit for a deduction at a chapter meet because of "corrosion" on that bar. That was how it was interpreted. I didn't fight it because it was only one point.
        I left that bar as is from the factory, I haven't touched it. So I'm assuming it is still correct.
        Chris Enstrom
        2011 Z06, red/red
        • Harry S.
          • July 31, 2002
          • 5344
          Chris, that bar is to drain water away that makes it through the weatherstrip. At each end of the bar, outside by the rear wheels there is a hole that allows water to drain from the bar and onto the ground. If those holes are plugged, water stays in the bar and will rust it out from the inside. There is a Restorer article I wrote several years back on removing the bar, fixing the rust and re-installation. I am on the road and can not recall the Restorer number.
          When it does rust water will drain on the inside, rusting the hinge, spring and wetting the carpet.
          • Alan D.
            • January 1, 2005
            • 2053
            Chris, posted a few pictures of the rear carpet area before, look at my second post it shows the bar of interest. Note the over spray of red primer and the black body color.
            Think your under deck is a little too glossy. Also note the upper edging of the rear carpet is not finished, ie no edging (that could cost point)
            These are from a Mar64 with original carpet in rear. Put ref at end since once it was pasted could not turn off bold.
            Take a look at the title -
            " 63 carpet; kick pads and wheel well
            • Chris E.
              • November 3, 2006
              • 1335
              Harry, my bar doesn't look rusted in the picture, does it? It just looks like it has red primer overspray. Maybe I'm ok on that point?
              Chris Enstrom
              2011 Z06, red/red
              • Chris E.
                • November 3, 2006
                • 1335
                On the gloss of the underside of the decklid, I'm going to fix that. On the carpet, we'll have to see if anyone catches that. No one has yet. If they do, it's only another point.
                Chris Enstrom
                2011 Z06, red/red
