Alternator pulley question - L79 without AC or PS - NCRS Discussion Boards
  • Chris E.
    • November 3, 2006
    • 1335
    Ok, so I was looking over my car in final preparation for the Iowa Regionals tonight. I came across the section in the TIM/JG where it gives the part number of the alternator pulley. Here is what I have:
    3829587-AI
    The book says I should have 3909815-AJ because I have the L79 (350 horse) WITHOUT A/C and WITHOUT Power steering.
    Is that true?
    I think I just replated my original pulley, that's why I'm wondering.
    Also, was this part number the same in '66 on the L79 without AC & PS?
    Chris Enstrom
    2011 Z06, red/red
    • 43247
    Re: Alternator pulley question - L79 without AC or PS
    3829587-AI
    Is that true?
    Chris------
    If the book says that you should have a GM #3909815, then the book is wrong. The 3909815 is a pulley and fan assembly. It was used on 300 hp engines but not L-79.
    Your application should use a GM #3871242. The same was also used for 1966 without C-60, N-40, or K-19.
    • Wayne M.
      • March 1, 1980
      • 6414
      ....... The 3909815 is a pulley and fan assembly. It was used on 300 hp engines but not L-79.....
      Chris -- here's two alt. pulleys w integral fan. The one on the right is the 3909815_AJ (you can see the stamping) that your book refers to.
      • Chris E.
        • November 3, 2006
        • 1335
        Ok, so the stamping I have is on the PULLEY, not on the fan......is that right?
        Chris Enstrom
        2011 Z06, red/red
        • R N.
          • May 31, 2002
          • 640
          Hi Chris,
          I believe that's correct, I also believe the pulley is a deep groove
            • 43247
            Chris------
            In your case, the fan and the pulley are separate pieces. There is usually no part number, at all, stamped on the fan.
            • R N.
              • May 31, 2002
              • 640
              Like this one....
              • Chris E.
                • November 3, 2006
                • 1335
                Originally posted by R. Kurt Neiman (38038)
                Like this one....
                YES, that is the one that I have with the part number stamped on the PULLEY.
                Is that correct?
                Chris Enstrom
                2011 Z06, red/red
                  • 43247
                  Is that correct?
                  Chris------
                  Assuming that you have an L-79 WITHOUT C-60 and WITHOUT N-40, I believe that GM #3871242 was originally used for your application.
                  I would not completely rule out the possibility that the GM #3829387 was used, though. It's just not what I would expect.
