70 brake bleeders supplier - NCRS Discussion Boards
  • Bill L.
    • February 1, 2004
    • 1403
    Can someone point me in the right direction regarding the correct bleeders for my 70. Calipers were rebuilt with stainless and I am looking for the correct bleeders with correct finish.
    Thanks! Bill
    • 6950
    Re: 70 brake bleeders supplier
    Bill, some of the auto part chain stores have a (Help) section of parts, and maybe you can find some zinc plated bleeders, or maybe if you have some zinc paint spary or brush a few coats on them, make sure theres no brake fluid on the bleeders.
      • 43248
      Thanks! Bill
      Bill------
      Any of the following Dorman part numbers are bleeder valves virtually identical in every way to the GM #5469230 bleeder valves originally used on your car. The only difference between these numbers is the packaging; the part is the same regardless of which number you get.
      Dorman #13903
      Dorman #313953
      Dorman #484-146.1
