66 Powerglide fluid substitute? - NCRS Discussion Boards
+ More Options
Posts
  • Richard W.
    • May 31, 1988
    • 58
    My 66 Powerglide trans has a leak. The selector shaft I think. I need to top it off. But I can't find any Type A which is what I believe is the correct fluid type. Is one of the modern types Ok (or better) to use in a 66 Powerglide as a substitute?
    Rick Weltzin
  • Larry M.
    • January 1, 1992
    • 2701
    Re: 66 Powerglide fluid substitute?
    You can use DEXRON or DEXRON II. They are downward compatible to Type A.
    However, if you still have the old Type A in the trans, you should consider a complete changeout after all these years. You"ll then be good for another 20-30 years.
    Larry
    • Richard W.
      • May 31, 1988
      • 58
      Larry,
      Thanks for the info. Yes, I'm not sure exactly what is in there but whatever it is, it has been there for at least 20 years.
      Rick
      Rick Weltzin
