67 L-79 Oil Drain plug - NCRS Discussion Boards
  • Lawrence S.
    • April 1, 1993
    • 801
    I looked in the Technical Info and judging guide for the specs on the above and it states that the plug is supposed to be 3/4" across the flats, that I can understand, further it states that the plug's thickness is 1/8" Is this correct? This seems very thin. If so can someone post a picture?
    Was there a Corvette application where the oil drain plug was 11/16" across the flats?
  • Keith B.
    • March 7, 2008
    • 928
    Re: 67 L-79 Oil Drain plug
    it should be 7/8 hex head plug. they were used on all kinds of other GM engine oil pans
    • Lawrence S.
      • April 1, 1993
      • 801
      Thanks Keith
      • Lawrence S.
        • April 1, 1993
        • 801
        Keith,
        I just checked the judging guide again and it says that the oil drain plug is 3/4" across the flats not 7/8". What is correct, anybody?
        • Wayne M.
          • March 1, 1980
          • 6414
          Originally posted by Lawrence Shaw (22476)
          Keith,
          Seems that all the C2 manuals just copied one another on this one (can't speak for the most recent '63/4 and the new '66).
          It's 7/8" but I'd say a tad thicker than just an eighth. Ignore the magnet tip; this was a later iteration on some engines, I believe. Also circle 'A' headmark is one of several typicals.
            • 15601
            Wow Wayne. That is a great picture. One can see the radial lines from the hot heading operation that formed the hex, and the sheer mark halfway down the hex from the sheering operation to size the hex. Nice detail.
              Larry -
              You must not have the latest edition of the JG - that item was revised five years ago, in the second printing of the fourth edition in 2005, as 7/8" across the flats and 1/4" thick.
              • Lawrence S.
                • April 1, 1993
                • 801
                Hi John,
                Yes you are right. I bought the JG in 2004 when I started my resto.
                Lawrence
                • Gary S.
                  Super Moderator
                  • February 1, 1984
                  • 457
                  Measurement
                  Avatar--My first ever vette, owned 3X since 1977, restored 1993-2024. Top Flight Award 9/14/24
