Self inflicted wound - NCRS Discussion Boards
  • Steve D.
    • February 1, 2002
    • 990
    In a recent thread, the board correctly diagnosed my problem (one of my problems) as a malfunctioning exhaust valve. I found a bent push-rod with the rocker off of the valve (#5 exhaust). After pulling the intake and measuring clearances, I determined that the length of the intake bolts (1.25" with a lock washer) could NOT be the reason. The scars in the inside of the bend had to be caused by something other than the intake bolt. Then I remembered that in the previous installation of the intake manifold (R&R'd to fix an oil leak) I had chased the threads in the head overhang to remove the liquid teflon that I use to prevent seepage up the intake bolts. I must have run the chase too deep and scarred/cut the push-rod. After it ran a while, the weak spot caused by the scar/cut gave way, the rod bent, the rocker slipped off of the valve stim, and the valve became in-operative. Clem would have never done that.
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Self inflicted wound
    i have seen too long of a bolt causing the problem BUT yours is a new one to me.
    • Steve D.
      • February 1, 2002
      • 990
      Clem
      I thought you had seen everything. Now I REALLY feel bad.
      Well, at least I'm # 1 at something!
      • Clem Z.
        • January 1, 2006
        • 9427
        Clem
        i would quit while you are ahead.
        • Steve D.
          • February 1, 2002
          • 990
          Your advice will be heeded. No more un-supervised thread chasing for me.
