midyear rear valance - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1314
    I'm looking to remove the side-pipes from my 1967 and put the exhause back under the car. I need a rear valance with the holes. There is one for a 1966 on ebay. Will this fit my 1967 or is 1967 unique?
  • Rob M.
    • April 30, 2003
    • 657
    Re: midyear rear valance
    Gerald,
    I believe that it would functionally be fine. The bare fiberglass on the inside may vary from '66 to '67 as far as how dark the gray color is - off hand I don't recall. I do know that it does vary from early C2's to the later.
    FWIW
    Rob
    '66 327/300 Regional Top Flt
    '08 6 speed coupe
    • Gerald C.
      • June 30, 1987
      • 1314
      Rob,
      Thanks. I have a 1963 valance already. Would that work on my 1967?
      Jerry
      • Mike G.
        • January 1, 1991
        • 418
        I've never owned a 66 or 67, but couldn't your existing panel be adapted by simply cutting the necessary holes for the exhaust bezels??
        • Dan H.
          • July 31, 1977
          • 1372
          Originally posted by Gerald Coia (11656)
          Rob,
          Jerry
          Jerry, 63 should have different holes sizes for smaller bezels, might check 67 bezels for fit, think you need a later rear valance though.
          Dan
          1964 Red FI Coupe, DUNTOV '09
          • Twan B.
            • June 30, 2005
            • 212
            Check out the date stamp on the rear valance.
            Gr,
            Twan
            • Gary B.
              • February 1, 1997
              • 7080
              Midyear rear valances; 64=65; 66=67
              Gerald,
              According to my notes:
              64 and 65 rear valances are the same
              66 and 67 rear valances are the same
              Gary
              • Bob R.
                • June 30, 2002
                • 1596
                Gerry,
                The 66 and 67 use the same exhaust bezel. The 63 bezel is smaller (one year only) and I doubt it would fit the 66 67 without modification. The 63 fiberglass is white and the 66 67 is dark. I don't think the 64 or 65 would work either. I think you need to search for a 66 or 67 valance.
                  Re: Midyear rear valances; 64=65; 66=67
                  Gary
                  That's correct - '64-'65 used the same stamped bezels, attached with three screws and U-nuts in a radial pattern through the "barrel" section of the holes in the valance, and '66-'67 used die-cast bezels with integral studs that went through holes in the face surface of the valance with stamped nuts on the inside.
                  You need a '66-'67 valance, with the corresponding die-cast bezels and nuts.
