Crossmember dent removal - NCRS Discussion Boards
  • Phil A.
    • April 30, 1982
    • 121
    Does anyone know if the dent removal tool sold by Terry at 509-235-5563 which is not a working number is still available? Thanks Phil
  • Grant W.
    • December 1, 1987
    • 407
    Re: Crossmember dent removal
    Send an email to Terry. tfringo@aol.com
    He is busy building a new house.
    Thanks, Grant
    • William C.
      • May 31, 1975
      • 6037
      All I know is they sure do work!
      Bill Clupper #618
      • Patrick T.
        • September 30, 1999
        • 1286
        Bill, I have never seen one of these tools. Do you or anyone else have a picture? Thanks, PT
          • 15640
          No picture -- I loaned mine out semi-permenantly. There are only about half-dozen pieces anyway.
          i will second Bill's comment about how well it works -- but I found it requires spring removal on C3s to get it into the inside of the crossmember.
            • 3422
            Hi,
            I believe the crossmember tool that Terry F. manufactures is offered by ZIP products. It's on page 4 in catologue #25, which I believe is the latest one. There is a picture.
            I've talked to some people who have used Terry's tool with good results
            • William C.
              • May 31, 1975
              • 6037
              Mine is on permanent loan to Bair's, after I let them use it on my car they were more than willing to keep it on "permanent loan" As mentioned above, it does require access to the inside of the crossmember thry the end of the member, not much of a problem if doing a body off, or major front suspension work.
              Bill Clupper #618
              • Patrick T.
                • 1286
                Ok, I found it on Zip's website, only $150.
                • Dick W.
                  • 10483
                  I wished that I had one when I was restoring cars. We took a cut off tool, cut the damaged section out, dollied it back to proper shape, and welded it back in. Dressed it down and painted, you could not tell anything had ever been done to it.
                  Dick Whittington
