Using an IR temp gun I got the following readings:
Upper radiator hose: 160-165* (remained at 160 until the temp gauge on the instrument panel hit about 205, then went to 165)
Thermostat housing: 197* when temp gauge hit about 205*
I do not know what thermostat I have. I am guessing that it either is not opening all the way if at all or may be a thermostat that is too high a temp range?
It seems clear to me that it should be changed but I want to know if I should be checking anything else.
During the winter the car ran plenty cool, never hit 210*. Now that it is warming up (70-80*) it is getting to 210 fast and pushing over a bit in heavier traffic. Here in South Louisiana it is only going to get hotter. Last summer a few minutes of idling caused it to push past 210 in a hurry and got hot enough to overflow a couple of times.
FWIW I have gone to manifold vacuum and my initial timing is 12*. Engine is an L72.
Thanks.
Thanks.
