Finish for strut rod cam spacer? - NCRS Discussion Boards
  • Steve L.
    • June 30, 2001
    • 763
    This is the spacer that fits inside the strut rod bushing to keep the strut rod from rattling on the cam bolt. There are 4 of these per car. This is for a 73
    Steve L
    73 coupe since new
    Capital Corvette Club
    Ottawa, Canada
    • 43279
    Re: Finish for strut rod cam spacer?
    Steve------
    If you're talking about the CAP used on each side of the strut rod bushing at the center bracket end, I believe they were a phosphate-like finish. I'm not sure it actually was phosphate, per se, but it had that appearance.
    By the way, there were 2 different caps used over the 63-82 period. One was used for 63-74 and one with a slightly larger OD was used for 75-82. The latter also became SERVICE for 63-74 more than 25 years ago.
    • Steve L.
      • June 30, 2001
      • 763
      thanks again Joe,
      Yes it's those caps. I would have guessed zinc plated since mine have only surface rust and seemed to survive.
      Phosphate it is. You can barely see them anyways.
      Steve L
      73 coupe since new
      Ottawa, Canada
