Exhaust Manifold Leaking - A Bit - NCRS Discussion Boards
  • Kirk M.
    • June 30, 2006
    • 1036
    For those who don't know, I just replaced both heads on my 67 327/300hp vette a few weeks ago. We initially installed exhaust manifold gaskets even though they are not NCRS correct. I took the DS set off two nights ago and now have a small leak that I can hear from the center portion of the manifold. It sounds a little bit like a loose rocker arm, but much softer and only audible from the DS of the car. When I had a loose rocker arm, you could hear the clatter from both sides of the engine. I must say that the manifold leak stops making any sound at all after a minute or two of engine warming. I am assuming the metal heats up and expands sealing the leak. Anyway, now I am torn about whether I should take the other side off (have AC so it is a bit more of a pain), or replace the gaskets (take the deduct) and not having a temporary leakage in my DS exhaust manifold.
    What is your vote?
    Kirk
  • Dick W.
    • 10483
    Re: Exhaust Manifold Leaking - A Bit
    Permatex Copper silicone is the trick to seal leaking exhaust manifolds. Just a thin bead around the exhaust port, not enough to squish out, and your leaks are fixed.
    Dick Whittington
      • May 31, 1974
      • 8382
      when rebuilding an engine, or anytime i have the exhaust manifolds removed, i take them to the local machine shop and have them surfaced to remove the concavity or convexity.mike
      • Bill I.
        • January 29, 2008
        • 554
        Dick, describe a 'thin' bead. Let's use a pencil as a guide, bead the size of pencil lead, maybe 1/8", or size of the pencil little over 1/4". Thanks, Bill.
        • Dick W.
          • 10483
          1/8" would be plenty. Let the silicone "skin" over before assembling it and you are good to go.
          Dick Whittington
            • 11643
            Agreed.
            I'd only think about the Permatex if you've already had them surfaced and then still have the leak.
            I think the leak will go away with surfacing.
            • Dick W.
              • 10483
              Patrick, I have never had one leak after using the Permatex. I even works well with tube headers, which are notorious about leaking gaskets.
              Dick Whittington
              • Timothy B.
                • April 30, 1983
                • 5186
                Dick,
                I never thought any material would stand up to the exhaust heat and pressure. Sounds like a good idea and cheep insurance if it works..
                • Dick W.
                  • 10483
                  Dick,
                  I started using it almost 25 years ago. I had a Chevrolet Dually 454 that I pulled my parts trailer with. I got a wild hair and installed a set of headers. About every 4-5k miles I would be replacing the gasket on one side or the other. I was at Bloomington and had blown a gasket. I was in the motel parking lot changing it and someone, who I do not remember the name, came up and suggested that I try the Permatex. I had the truck another 20k miles before it was stolen, and never had to replace a header gasket. I use it on everything exhaust
                  Dick Whittington
                  • Kirk M.
                    • June 30, 2006
                    • 1036
                    Did the copper High Temp Permatex last night to the DS. PS still has gaskets on it. Did it last night. Might give it a shot tonight and see if the leak is gone. Will let you know cause I hate it when people don't follow up on their questions/problems. If all goes well, I will remove the gaskets from the PS and do the same.
                    Kirk
                    • Joe C.
                      • August 31, 1999
                      • 4598
                      Dick,
                      Did you ever try sealing tube headers (assuming everything is flat) with high temp silicone and no gaskets. Torque the bolts to about 25 ft-lbs and forget them. Eliminate problem of gasket creep and constantly re-torquing flange bolts with the thick gaskets.
                      • Dick W.
                        • 10483
                        Originally posted by Joe Ciaravino (32899)
                        Dick,
                        When I cut the flanges it helped a little, but when I went to the silicone problem solved. Never thought that silicone alone would work. Tube headers are not exactly an example of perfect machining in the port area
                        Dick Whittington
