Need Pic of Original 67 AC Harrison Label - NCRS Discussion Boards
  • Kirk M.
    • June 30, 2006
    • 1036
    Anybody got a picture of an original Harrison AC compressor label for a 67 vette? I need the area showing the model number and serial number. Trying to track someone down who can label the serial number for us correctly, but they have asked for an original picture. Thanks.
    Kirk
  • Ian H.
    • July 31, 2004
    • 76
    Re: Need Pic of Original 67 AC Harrison Label
    Here's one I got from Tony Stein in July 2006. This board has reduced the file size substantially. If it's not good enough, I can email it to you.
    The Code No. appears to have been typed on with an impact typewriter whereas the Model No. appears to be printed with the label.
    • Peter L.
      • May 31, 1983
      • 1930
      Kirk - If you are going through the trouble to make the label as correct as possible, also note in Ian's photo of the compressor the configuration of the compressor case with the grooves near each end. This is typical of the original A6 compressors from the 1966/1967 era and newer. Older A6 compressor cases were tapered at both ends and did not have the grooves.
      Have fun. Pete
      • Larry M.
        • January 1, 1992
        • 2702
        Kirk:
        This has been covered before and is in the archives. You can check under my name, although it was someone else that made the final recommendation. Use an old IBM Selectric typewriter to mark the label.....there are many still around. The correct font and pitch were provided in the older thread.......although I guess just about any of the older fonts would work and look correct.
        The older thread also provided estimated dates/times to use prior to the car build. My AC compressor build was dated about 7-8 weeks prior to my March 28 car build date. I would think that four to six weeks would be a good choice for 67 cars.
        Larry
