57 screws - NCRS Discussion Boards
57 screws
  • Chris S.
    • March 28, 2007
    • 139
    57 screws
    Can i get the type or picture of 4 screws that drill thru gutter that combines the top fender to the inner fender. I can't quit make out what type of screws these are. you can only see these with the hood open and from the top. Not sure what the real name is where these are located.
  • Steve H.
    • November 1, 1996
    • 118
    Re: 57 screws
    Chris,
    These are the regular Phillip head thread cutting type that are used all over the car. My car uses three on each side.
    Steve
    • Chris S.
      • March 28, 2007
      • 139
      Re: 57 screws
      i recall seeing one aaaabout midway, and toward the front. Where these unpainted? #8 phillips simiral to most of the screws in the engine compartment.? THe last two holes must be near the windshield area?
      • Mike M.
        • May 31, 1974
        • 8382
        Re: 57 screws
        the # of pan head phillips self tapping screws that secure the front surround to the inner skirts varied from 56- 57. i've seen some with 4 per car, some with 6 per car. never seen what i considered an unmolested 56-7 with no screws. can't recall if the assembly manual illustrates the screws and i'm not near my 56-7 AIM. mike
        • Mike M.
          • May 31, 1974
          • 8382
          Re: 57 screws
          chris: the male hood pins on your 57 are not serrated like the ones on your 62. if one uses the serated pins on a 53-57( to prevent the hood from drifint upwards while its out on a highway), its considered a "performance enhancement" and hence is a cause for PV failure. i usually put about 500 miles on a just restored vette and i run the PV test a half dozen times before presenting a vette for PV. mike
          • Steve H.
            • November 1, 1996
            • 118
            Re: 57 screws
            Chris,
            Their placement varies. They are plated screws that are painted body color during body painting. The first one on my car is about at the hood prop and the last one is where the inner finder goes back into the outer fender cavity (close to the battery). The middle one is about halfway between the two. They are the same on both sides.
            Steve
            • Roy B.
              • February 1, 1975
              • 7044
              Re: 57 screws
              It's also one way of knowing weather the fenders were
              Replaced or damaged , having to many or to few screws . For 53 to 55 I look for the "rivets" first to see if a fender was replaced by counting the rivets on the R (8) & L (8) fenders . Air vent body area (8) and the (4) at the radiator area. Total of (28) rivets . This blue 55 sold on e-bay restored stating it had no body damage = but then it has (10) rivets installed on the right fender for 200K . So it must of had damage. Da!
              • Garry B.
                • January 1, 1991
                • 660
                Re: 57 screws
                I hope this helps. If you look at the very top of the picture you can see the placement of all three.
                Garry Barnes 18531
                Garry Barnes #18531
                '67 Lynndale Blue Coupe- National TF, BG
                ​'67 Sunfire Yellow Coupe- 4 Star Bowtie,
                • Steven B.
                  • June 30, 1982
                  • 3986
                  Re: 57 screws
                  Thanks Roy! I never checked '53-'55 and would have assumed screws were used.
                  Steve
                  • Chris S.
                    • March 28, 2007
                    • 139
                    Re: 57 screws
                    i can see two, the picture must of cut the third one off?
                    • Garry B.
                      • January 1, 1991
                      • 660
                      Re: 57 screws
                      Look across the top of the picture. There are definitely three there. If you look at the center screw, look to the left about a foot to see the most forward one. The screw most rearward is directly across from the one in the foreground on the drivers side. The front screw on the drivers side is cut off in the photo. This photo was taken a few years back before I sold the car, so I am unable to take new ones showing everything you want to see.
                      Garry 18531
                      Garry Barnes #18531
                      • Steven B.
                        • June 30, 1982
                        • 3986
                        Re: 57 screws
                        'directly across from the ignition shielding is the third one.
                        'Beautiful car!
                        • Garry B.
                          • January 1, 1991
                          • 660
                          Re: 57 screws
                          Thanks Steve. I wish I still had it.
                          Chris? Did this get you what you need??
                          Garry 18531
                          Garry Barnes #18531
                          • Randy G.
                            • April 1, 2006
                            • 358
                            Re: 57 screws
                            Roy:
                            My '54 has 8 on the each of the fenders, 4 at the radiator area and 7 at the cowl. It's a no-hit car.
                            Randy
                            • Gary C.
                              Administrator
                              • October 1, 1982
                              • 17657
                              Re: 57 screws
                              Chris, was told along time ago when I questioned the number of screws in Bloomington one year in the 80's and a fellow (have forgotten his name - CRS) that used to work at St.Louis said the number of screws used often depended upon how well the inner fender fit as the screws were to secure them together until the resin set. Nothing in the AIM other than the reference to Top Panel Instruction # 3725743. FWIW, Gary....
                              NCRS Texas Chapter
                              https://www.ncrstexas.org/
