Help to ID 63 brake master cylinder - NCRS Discussion Boards
  • Wj H.
    • April 2, 2009
    • 3
    Gents: i have a 63 coupe. Brake master cylinder leaking from back. I have not pulled it yet, but it is not a typical 63 thumb screw design. Looks like the remans you see on ebay when you punch in 1963 Corvette master cylinder (picture of lookalike below). However, mine says Wagner Lockheed underneath and number appears to be
    FE 493808. I am willing to stick with this for awhile until I can find a correct one, but I cannot find any reference to a Wagner # even close to this number.
    Like I said it looks just like this, even with the bleed valve, but this pic is not a Wagner Lockheed. Any idea what mine is/ from and do you think a 64 rebuild kit would work. Thanks,
  • Rick A.
    • July 31, 2002
    • 2147
    Re: Help to ID 63 brake master cylinder
    well, definitely not original to your car
    Rick Aleshire
    2016 Ebony C7R Z06 "ROSA"
      • 43247
      WJ-------
      If the number "FE 493808" is a casting number, you're likely not going to find it shown in any catalog or other available reference. It won't be a part number and might not even be a Wagner number, at all (i.e. it might be a foundry number of some sort).
      I have not heard of the "Lockheed" attached to "Wagner" for MANY years. What I would say you have on the car is an older, aftermarket, service-replacement type master cylinder. It's very possible, though, that Wagner (now part of Federal-Mogul) continues to produce master cylinders of the same configuration as the one on your car and that's what you're seeing for sale (although they might not be branded Wagner).
