67 BB Vacuum Advance Help - NCRS Discussion Boards
  • Dereck S.
    • July 30, 2008
    • 244
    I purchased a replacement distributor vacuum can for my 67 427/400 (without TI) car. The new can is a 360 12 from LI Corvette. The can that was on the car was corroded and I wanted a fresh cad look. The can I removed was marked 446 15. I was surprised to find this. I noticed a change in run quality with the new can. Although nothing significant. Can anyone help me determine what the 446 15 is from and could it indicate that I may have an incorrect replacement distributor. I'm debating whether to put the 446 15 back or purchase a replacement with the same number.
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 67 BB Vacuum Advance Help
    From Delco Remy Test Spec's DR-324S-2 1964-1976 supplement.
    The 360-12 is correct for your 1111247 L68 distrib. The 446-15 is common on many in the 1974 era (1112247 '74 base engine Corvette, for instance).
    The specs are quite similar: for the 201: 7-9"Hg to start advance; max adv @ 15-16"Hg; 8 deg max distr. adv. (ie. 16 crank degrees)
    for the 446: 5-7"; 13-14"; and 7.5 deg., respectively.
    I think the 446 was available in service for a while, in the '70s.
    • William C.
      • May 31, 1975
      • 6037
      Do yourself a favor and actually check the operation of the reproduction vacuum can against the specs. In my experience many are not even close to the proper spec, regardless of the number on the can.
      Bill Clupper #618
        • 43289
        Bill------
        Yes, it's one of the maladies that exists in the "world of reproduction parts" where form often trumps function.
        • Dereck S.
          • July 30, 2008
          • 244
          Wayne,
          What would be the part number for a direct replacement for the 446 15? I've done some checking and the 446 15 is an obsolete part.
            • 15706
            The VAC is worth a total of 3 points - two for originality and one for condition.
            I deduct one point if the VAC is replacement "B-number", and the one I recommend for all big blocks is B20 or B26, both of which are 0 @ 6", 16 @ 12".
            Recent information is that the B10 is an exact match to the OE 360 (0 @ 6", 12 @ 12"), but it hasn't been verified. The 446 is not the original part number and its specs don't suit big blocks, i.e. it doesn't meet the "Two Inch Rule".
            You can do an archive search for B20 and B26 to get a list of brands/part numbers, but I don't think there's any mention of a brand/part number for the B10.
            Regardless of what brand you buy, including Delco, it's the same part made by Standard Motor Products.
              • 43289
              Wayne,
              Dereck-----
              The aftermarket replacements for the GM #1973446 are as follows:
              Delco #D1377A (same as the original Delco part #, but not the exact same part)
              NAPA/Echlin #VC-1807
              Standard Motor Parts # VC-183
              All of the above are manufactured by Standard Motor Parts and should be stamped "B25".
                • 43289
                Duke------
                I believe the "B10" vacuum control is available as follows:
                NAPA/Echlin------VC-1765SB
                Delco--------------D1383X
                GM-----------------19138049
                • Dereck S.
                  • July 30, 2008
                  • 244
                  All,
                  The negative change in run quality was coincident with another issue that arose when I changed the can. After changing the can I got the car out on the highway and stretched it's legs. After that the run quality wasn't where it had been prior to the can change. This lead me to believe the can was to blame. Upon closer examination (taking many hours) I found that the butterfly on the rear carb was slightly hung open on a burr in the bore. After addressing this by a careful deburr the car ran better than ever even with the new can. Clearly the can change was not the issue here. I'm glad to have the correct can 360 12 on the car. Goes to show you have to be patient and more scientific when attempting to isolate issues. Thanks for all the help.
