Engine operation troubleshoot - NCRS Discussion Boards
  • Steve D.
    • February 1, 2002
    • 990
    63 convertible, small block
    I hear a popping sound through the carburetor when accelerating or at rest when bumping the throttle . Initial timing is set at 9 deg.
    Background: No popping noise experienced until after I yo-yo'd the intake manifold to fix an oil leak. I had marked the distributor orientation and thought I had dropped it back in the same spot. The engine started right up. I drove it a while and it seemed to be running a little hot. At one point when I was stopped, the engine suddenly died. It started easily, but then I started hearing the sound when accelerating. I went home and shut it down. Next day it started right up, but I still had the popping noise when bumping the throttle (no noise at idle). I noticed that the distributor hold down was not tightened, so I snugged it down. I let it idle to warm up before checking the timing. After idling about 5 minutes, it suddenly died. Would not restart. Let it cool a bit and it started right up. Checked the timing and found it to be 16 deg. Set it to 9 deg., but popping noise still persists. The engine is NOT spitting gas and backfiring through the carburetor. Comments?
    Steve
    • 6948
    Re: Engine operation troubleshoot
    Steve, it may be possiable that the two center intake manifold bolts on each side may be to long and are contacting the push rod or rods, there are a few different length bolts on the intake. if a longer bolt is contacting the push rod it will cause the valves not to open and close properly. the best way to check this is to is pull the valve covers of and look at the push rods on the 2&4 and 3&5 cylinders. start up engine and check the movement on the push rods.
    • Loren L.
      • April 30, 1976
      • 4104
      Coil. Can someone tell me why this ystem insists on extra meaningless characters? Is it owned by a Congressman?
        • 6948
        Loren , Sorry my typing skills are not the best.
        • Steve D.
          • February 1, 2002
          • 990
          I neglected to mention that I replaced the coil before I started the engine the next day. A friend had suggested that as a possible problem, so I changed it as part of the process.
          • Loren L.
            • April 30, 1976
            • 4104
            I don't understand - my comment was Why Mr. Waggoner's sytem just wouldn't accept a one word response - coil. Had nothing to do with your response at all.
              • 6948
              Loren, oh, I thought it was my typing era.s if you read my post.was not good .
              • Dick W.
                • 10483
                None of the Vbulletin based forums will take a one word response. VH will not take a one word response
                Dick Whittington
                • Wayne P.
                  Infrequent User
                  • July 31, 1995
                  • 3
                  I am sure you will find one exhaust valve not opening .Could be rocker arm off of cam lobe worn excess. I have diagnosed more than a few with this problem . let us know what you find.Here is what happens .The intake opens and air and fuel come in on intake stroke then up on compression,ignition occurs,down goes the piston, then up on exhaust, but the exhaust valve doesn't open,leaving pressure in the cylinder,and now the intake valve opens and you get your pop in the intake which you hear at the carb.I saw this a lot in chev motors early 70's. their were some cam problems.You can find which cylinder by disabling spark to one cylinder at a time ,then excellerate,or just pul both valve covers and inspect.I also had this problem on an engine that had one exhaust port restricted,but thats unlikley.Let us know
                  Goodluck Wayne
                  • Mike H.
                    • February 1, 1980
                    • 45
                    Did you remove the plug wires from the dist. cap and get a couple out of order upon reinstalling?
                    CORDially Mike
                      • 6948
                      Steve, how did you make out with the problem? Just wondering.
                      • Steve D.
                        • February 1, 2002
                        • 990
                        Edward
                        You nailed it. When I pulled the driver side rocker cover, the first thing I noticed was #5 exhaust rocker sitting askew. I loosened the rocker and pulled the rod. It was slightly bent and had thread marks on it on the inside of the bend.
                        What are the chances that the lifter (solid) was damaged in the process?
                        Steve
                        • Steve D.
                          • February 1, 2002
                          • 990
                          Corbett
                          You were right. See my reply to Edward above.
                          Steve
                          • Wayne P.
                            Infrequent User
                            • July 31, 1995
                            • 3
                            Is unlikely any damage was done to lifter other than it could jump out of lifter hole, but you can tell when you install push rod.
                            wayne 26443
                            • Steve D.
                              • February 1, 2002
                              • 990
                              Wayne
                              The lifter is still in place. Thanks.
                              Steve
