side glass drop in 58 - NCRS Discussion Boards
  • Brad H.
    • August 12, 2007
    • 724
    Book says just drop it in etc. installing side glass and can not get the roller to drop in the track, 1/2 off, what do you do? Loosen door post? Thanks, Brad.
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11366
    Re: side glass drop in 58
    Brad,
    No you should not have to pull the door post. I pulled 2 off of a 59 not too long ago with no problem so it should go back in the the same way it came out. You may just have to raise or lower the regulator arms a bit more than you're doing.
    Rich
    • Brad H.
      • August 12, 2007
      • 724
      Had to loosen door posts to get window roller to drop into track, no way else would work. Thanks, Brad.
