Distributor Identification? - NCRS Discussion Boards
  • Mark A.
    • February 1, 1996
    • 299
    I HAVE A DISTRIBUTOR THAT I CANNOT FIND OUT WHAT IT CAME OFF OF. I REMOVED IT FROM A 57 CHEVY BEL-AIRE. IT IS A TACH DRIVE, DUAL POINT UNIT. IT IS MADE BY MALLORY. THE ID PLATE SAYS PART # YC-465-HP. CAST INTO THE SHAFT HOUSING IS THE NUMBER T310 C 465. DOES ANYONE HAVE AN IDEA WHAT THIS DISTRIBUTOR WAS FOR? DID ANY OTHER GM VEHICLES USE TACH DRIVE DISTRIBUTORS OTHER THAN THE CORVETTE?
  • Dick W.
    • 10483
    Re: Distributor Identification?
    It was designed to be used on any Chevrolet that needed a mechanical tach drive
    Dick Whittington
      • 43246
      Mark------
      I'd say it's just an old aftermarket-type tach drive distributor. The only Chevrolet model that I know of that used a tach drive-type distributor was Corvette. However, it's possible that those few passenger cars in the mid-50's that were equipped with FI also used a mechanical tach. I doubt it, but it's possible.
      Being an aftermarket-type piece, I doubt very much that it was designed for a very specific application (like Delco-Remy distributors used on GM vehicles). It's more "generic" but, since it has tach drive, probably mostly intended for Corvettes.
      Also, mechanical tachs were used as an aftermarket-type retrofit piece for all sorts of cars in the 50's and 60's. So, this distributor could also have been used for that sort of application.
      • Mark A.
        • February 1, 1996
        • 299
        Thanks Dick And Joe For Helping Me Figure Out The Mystery! Mark
        • Richard D.
          • December 1, 2002
          • 328
          Found this info -
          VintageIgnition
          09-23-2005, 02:15 PM
          YC-465-HP is for small & big block Corvette w/ tach drive. This a mechanical advance dual point "double-life" distributor. Fairly rare.
          ...on this link - http://www.348-409.com/forum/archive...hp?t-5282.html
          Take a look at some of the old Mallory catalog pages posted on this link -
          http://www.jalopyjournal.com/forum/s...d.php?t=449646
          ...and it appears that the "YC" designated Corvette on one of the pages, and also the "465" is used on the 68 Corvette dist. designation.
