Original Tower Hose Clamp Cleanup - NCRS Discussion Boards
  • Larry E.
    • 1692
    Hello:
    Rummaging through my garage the other day and found some of my
    brothers original 66 Corvette Hose Clamps. (Dated 4/66) (He bought
    the car in NJ brand new in 66 for about $3900 as I recall!) Anyway what
    would be the best way to clean them up? A lot of grim and dirt on them.
    I got them soaking in solvet for
    now. Would sandblasting them be to harsh on them and erase the markings? Emery cloth perhaps. Give me some ideas to make them look
    new.
    Larry
    Larry
    LT1 in a 1LE -- One of 134
    • 15616
    Re: Original Tower Hose Clamp Cleanup
    Original tower clamps made by Wittek, Chicago IL were slit from galvanized sheet. I have seen a number of attempts at electroplating the assembled clamps, but none of them have looked like the original finish. Perhaps there is a secret out there yet to be revealed.
    So based on that observation I would caution you against using any abrasive unless the clamps are rusty -- in which case the original galvanizing is already gone in the area that is corroded -- and you then have nothing to lose.
    • Harmon C.
      • August 31, 1994
      • 3228
      I use low air pressure walnut shucks and a quiick blast with the foot pedal. Get some old junk parts to test your method before you make junk out of good parts.
      Lyle
      • John D.
        • December 1, 1979
        • 5507
        Larry, Once you have the grime off/from the clamps try this trick.
        Go to NAPA and get some "Twin Etch". It's not cheap.
        For your clamp go borrow a glass or plastic measuring cup from the kitchen.
        Put in a 1/2 oz shot of Twin Etch and the rest water. Swish the mixture around. Then put the clamp in and swirl it around for about 20 secons. Remove it quickly and rinse with water and blow dry.
        Won't be perfect but it will be an improvement.
        Twin Etch is phospheric acid, etc. Good stuff.
        Say your friends cad plater gives you back a piece that looks like someone threw up on it. Has brown spots, etc. Give the part a bath in "twin etch" and water for 10 seconds or so and watch it come out real pretty.
        then give the part a squirt of Pledge polish and wipe dry.
        Hint: weak solutions are the trick. Strong solutions are to be avoided JD.
        Not to be critical but I keep reading here that members suggest glass beading steel parts before having them zincad. If you do it takes away the nice original grain of the metal and gives you a metal flake look.
        Yes glass beading is easy and quick. But it's not always the way to go. Of course if the part is totally trashed and very rusty then you have no other option.
        Trick is to strip the parts yourself with the proper chemicals. Then have your plater give you some of his soapy solution that you can soak the parts in at home so they don't rust on the way to the platers.
        I learned the plating preparation from my the founder of the Pittsburgh chapter. None other than Barry Holmes.
        • Larry E.
          • 1692
          Checked with local NAPA store and they indicate that the smallest
          quantity for "Twin Etch" is one gallon at $81.00. That's not all; none
          is available in the reginal NAPA network. Would have to try to go outside
          of region to get; then is only iffy to get it shipped. Any other ideas or
          products to help me?
          Larry
          Larry
            • 15616
            That sounds like a product that is on the edge of extinction. HHHmmmm.
            • Richard G.
              • July 31, 1984
              • 1718
              I wouldn't worry about it going out because of the EPA.
              Phosphoric Acid (Yes, that Chemical in Coca Cola)
              You may find it less expensive by checking with your local paint shop. It is also one of the active ingredients in in rust-mort and Areo-Kroil. You can get it is quart or gallons at Home Depot. Or just use Coke. It just takes a little longer that's all. Actually phosphoric does not dissolve rust it converts it to iron phosphate.
              Rick
              • Tom S.
                • March 1, 2004
                • 1087
                When I was a kid on the farm my grandfather used Coke to loosen rusty bolts for years. It worked, or so he thought!
                  • 6950
                  I was aways wondering why my stomach bothered me after each glass of coke .
                  • Dick W.
                    • 10483
                    Phosphoric acid comes under many names from many manufacturers. It is used to etch bare metal or aluminum prior to priming and painting. With the advent of the self etching primers it is not used as often as before. I would not be surprised if you could not buy a diluted version at Lowe's
                    Dick Whittington
                    • Larry E.
                      • 1692
                      I got them cleaned up a bit from my local powder painter who put them
                      in his small non abrasive blaster. He used non abrasive iron particles.
                      I hope these pictures show up OK. Here is the kicker: Found the upper
                      row of clamps dated 2/63; bottoms are 4/66. I'm not 100% sure all of
                      them came off of my brothers 66 S/B Coupe but am 99% sure. Question:
                      Could it be possible the car came with some 2/63 tower clamps?? I have
                      since sprayed the clamps with a product call "Fluid Film" a metal protector
                      which is talked a lot on the Camaro Discussion Boards.
                      Comments are always welcome. Thanks; Larry
                      Larry
