Firewall Insulation - NCRS Discussion Boards
Firewall Insulation
  • Tom L.
    • May 7, 2007
    • 438
    Firewall Insulation
    I'm replacing the rubber/jute firewall insulation to kick off the re-assembly of the interior. Paragon sells it for $390 and Zip has it for $189. Does anyone have any experience with either of these parts? Is the Paragon part worth an extra $200?
  • Joseph M.
    • June 30, 1999
    • 334
    Re: Firewall Insulation
    I recently used Paragons'. No major problems other than when reinstalling the throttle pedal assembly. We had to shave off some of the rubber and insulation to get the bracket bolts into the firewall. It wasn't the easiest task doing this under the dash.
    I don't know how this product compares to other manufacturers. I also thought it was a bit pricey.
    • Bill C.
      • July 15, 2007
      • 904
      Tom,
      That is what I paid nearly 2 years ago - I purchased from Paragon.
      Just as an FYI -- Doc used to have a guy that would make/supply the firewall pads AS ORIGINAL. His back log was about a 6-9 month wait.
      It is DEAD on perfect.
      I don't know if he is still making them to order and if Doc can still get the pads that way any longer. May be worth a call to him.
      But -- I am very satisfied with the Paragon unit. Only issue I had was fitting the gas pedal as stated above. Just took a little fitting etc...
      • Dick W.
        • 10483
        Some vendor is selling a piece of crap, molded plastic firewall insulation. Beware of this stuff. This may be the bargain priced insulation
        Dick Whittington
