L-36 freshly rebuilt along with my factory Holley carb , also over hauled, along with slightly larger jets. 66 T. F. car. All carb gaskets are new.
Upon firing her up after installing carb I now have this annoying whistling sound from the center of the carb.
The carb is snug to the intake but sounds like it's sucking air, thus perhaps the whistling sound
1) I believe the gasket sequence is Intake, gasket, metal baffle/heat shield, then carb...........pls correct if I'm wrong.......
2) Any thoughts on a high pitched whistling sound from main bowl area or below.
thank-you
thank-you
