Expansion Tank Cleanup..... - NCRS Discussion Boards
  • Larry S.
    • September 19, 2007
    • 204
    I have a '64 327 FI expansion Tank that I would like to cleanup. It looks good, but could look fresher and am wondering how I can make it look close to "like new" condition. Should I use a very (0000) fine steel wool or is that a "no-no"? Any suggestions will be appreciated.
  • Edward B.
    • January 1, 1988
    • 537
    Re: Expansion Tank Cleanup.....
    Even the finest steel woll will leave little pieces behind that will soon turn into rust spots.
    • Edward S.
      • December 1, 1986
      • 514
      Do they make oooo fine brass steel wool?
      • John F.
        • March 23, 2008
        • 2421
        I would etch it with a diluted muriatic acid and water solution. Use a soft brush or old tooth brush. Should clean it up a little.
        John F
        • Troy P.
          • February 1, 1989
          • 1284
          Any kind of steel wool will make it shiny - not good. You could use it to clean it up but would then need to use a chemical wash of some sort (phophoric acid perhaps, like metal prep) to make it dull again.
          • Larry S.
            • 204
            Thanks, as that gives me some ideas as to what to try. Maybe an aluminum cleaner?
            • Jean C.
              • June 30, 2003
              • 688
              Larry,
              If it were my tank and I intended to clean it, I would test the various suggested products on a part of the tank that is not visible when installed. Then I would be damn sure that I wanted to do the entire tank before proceeding. On a similar note, I once polished a brass antique cigar humidor...one of the dumbest things I have ever done (and there have been several I can assure you) was removing the patina from that piece.
              Best regards,
              • Troy P.
                • February 1, 1989
                • 1284
                Yes, that would be worth a try. If you can get an old leaking tank at a swap meet to experiment on that would be the best approach.
                • Michael M.
                  • February 1, 1993
                  • 606
                  Larry I had good results with a aluminum trailer cleaner. It removes any oxidation from aluminum therefore it brightens the metal. The product has to be diluted because it is a acid. If interested the company is called BAW Group in Fairfield N.J. and the plone number is 800-851-1443. Please read the directions.
                  • Christopher R.
                    • March 31, 1975
                    • 1599
                    John F
                    I wouldn't do that. Maybe if you diluted the heck out of it. But as it comes out of the jug, it'll turn aluminum black.
                    • Jerry G.
                      • April 1, 1985
                      • 1022
                      I have used an "aluminum paint prep" in a diluted solution. I think it's Phophoric acid . sold at auto paint stores. Works well in giving it a clean "as cast" patina
                      • Larry S.
                        • 204
                        Thanks for all your ideas. A friend of mine has an old damaged tank that I will use to test cleaners on first.
                          PS: There IS an aluminum form of Naval Gel (basically phosporic acid) designed for just this kind of application...
                          • Roy H.
                            • January 6, 2009
                            • 40
                            Has anyone ever tried walnut shells in a bead blast cabinet ?
