67 tank sticker - NCRS Discussion Boards
67 tank sticker
  • John R.
    • November 1, 2005
    • 433
    67 tank sticker
    Do not have much remaining of my tank sticker. Wondering if someone can tell me if the code, O2U69E8(or 3 vs 8, hard to tell) for the radio means anything other than am fm radio. Noted from other posts that power brakes are listing on the same row as radio with another code. Any help would be much appreciated. Thanks!
    Re: 67 tank sticker
    John -
    The "02U69EA" radio code means the car has the L-36 engine, and the "02U69EF" radio code means the car has the L-68 engine with A/C. The 2-character alpha suffix is an ECL code that identifies the Engineering parts list for the radio installation with other options that affect it. There were no "E3" or "E8" ECL codes used with U69.
    • Wayne M.
      • March 1, 1980
      • 6414
      Re: 67 tank sticker
      John -- per Noland's Vol 2, the possibilities with ECL 2-letter suffix starting with 'E' are: EA = L36 w/o C60; or EF = L36 w/C60. If you suspect that the E might be an 'F' there are others: FA, FB, FE, FF, and I or others could provide.
