65 spark plugs - NCRS Discussion Boards
65 spark plugs
  • Joseph P.
    • September 7, 2009
    • 138
    65 spark plugs
    Do I use the little aluminum ring that comes with the spark plugs. If yes does it go with the flat side against the plug or towards the block? Thank you Joe
    Re: 65 spark plugs
    Joe -
    Yes, you need the gasket - it's the combustion seal between the plug shell and the cylinder head. Doesn't matter which way it's installed - works fine either way.
    • Joseph P.
      • September 7, 2009
      • 138
      Re: 65 spark plugs
      Thank you John, It's been a while since I've seen them and didn't know if the 65 needed them. Joe
