Air Filter help ! - NCRS Discussion Boards
Air Filter help !
  • Tom S.
    • March 1, 2004
    • 1087
    Air Filter help !
    I need a filter element for my 65. It is a A/C A165C. I cannot find one through A/C , NAPA/WIX, FRAM, PUROLATOR OR Fleetguard. Any idea where I can get a new element, i'm sure I am not the first to run into this. Thanks Tom
  • Michael J.
    • January 27, 2009
    • 7180
    Re: Air Filter help !
    Corvette Central has it for $50, part#152016. Foam element, right?
    • Tom S.
      • March 1, 2004
      • 1087
      I don't know if it is foam or not. I don't have one to compare to. Mine is missing. I think it would be a paper element but I don't know for sure? Tom
      • Michael J.
        • January 27, 2009
        • 7180
        According to the replacement guide, the paper element one is AC A212CW, and it was used on the '65 396 and the '66-'70 for all open element air cleaners. The A165C was used on the 327 with the snorkle air cleaner.
        • Wayne M.
          • March 1, 1980
          • 6414
          Tom -- this is what you'll need but you'll NEVER find an NOS one now. Got this back in the early '80s; now turned to dust . there's a paper element GM replacement, good for a driver (the AC number escapes me now, but it's something like AC-353) drops right in the air cleaner housing.
          • Harry S.
            • July 31, 2002
            • 5349
            Is this what you need?
            https://www.forums.ncrs.org/attachme...16939&uid=7546
            Check the archives, as I recall there is a link to who has them.
            • Louis T.
              • July 31, 2003
              • 282
              Hi Tom,
              Assuming your filter is the same size as that in my '65 365 hp (and I'm pretty sure it is), you should be able to use a disposable Wix 42070 (for driving purposes, of course, not judging). See the link below for measurements. NAPA carries an equivalent as well.
              Louis
              • Dick W.
                • 10483
                Originally posted by Louis Trohatos (40341)
                Hi Tom,
                Louis
                http://www.wixfilters.com/filterlook...asp?Part=42070
                Wix makes NAPA and Carquest filters. You can just take the Wix # to either and they can cross it for you.
                Dick Whittington
                • Michael J.
                  • January 27, 2009
                  • 7180
                  Right, and if you get the NCRS correct-for-judging A165C foam element you will also need the screen. But if you don't care about judging go with the Wix paper substitute.
                    • 43291
                    Michael------
                    If you care about your engine, make sure you don't use the reproduction A165C for anything other than judging. The A165C was a miserable excuse for an air cleaner and, fortunately, GM figured this out fairly early-on (but not as early as they should have). The GM #6419399, aka A165C, was discontinued from SERVICE in November, 1968 and replaced by the GM #6484399, aka, A353C. The latter is a cellulose fiber (paper) filter and it will filter air WAY BETTER than the A165C.
                    The GM #6484399 has been discontinued now. However, you should be able to get an equivalent replacement from other manufacturers. However, you'll need to cross reference from the 6484399 or A353C part numbers. The A165C is such an "ancient" part number that I doubt that any cross reference guides will recognize it.
                    • Michael J.
                      • January 27, 2009
                      • 7180
                      Michael------
                      Right, I suspect it was just a terrible as the foam one I have (for judging only, a K&N otherwise) on my L71 with the triangular air cleaner. Why they put those foam things on is beyond me.
                        Tom -
                        Long Island reproduces the A165C now, and the support screen.
                        • Tom S.
                          • March 1, 2004
                          • 1087
                          Thanks to all who helped. I appreciate it.Tom stanton #41491
