Caliper paint and baking - NCRS Discussion Boards
  • Michael W.
    • April 1, 1997
    • 4290
    Re: Caliper paint and baking
    Originally posted by Joe Tutela (46448)
    AH...But dry?
    Brake calipers seals are not made of rubber.
      • 43222
      AH...But dry?
      I have take calipers apart to hone the cylinders (pre-stainless) and never had a problem with the re-assembly. But if they will get hot enough from use, why not?
      Joe------
      I hope you didn't hone them very much. GM never recommended honing these and I have found that honing caliper bores almost always ends up with a leak from the honed bore.
      • Joe T.
        • October 25, 2006
        • 304
        #18
        Joe------
        I honed them with a brake hone so the stones were very non-aggressive. I did it as part of a rebuild to try to correct a leaking piston. It helped for a little while, but they were never quite as good as new, hence the eventual replacement with the stainless steel sleeved version. Now I am contemplating moving to the newer seal/piston technology
