HEI Distributor Tach Problems - NCRS Discussion Boards
  • David M.
    • March 14, 2010
    • 1
    Good Morning All,
    I have replaced the stock points distributor in my 70 350CI with a HEI and now my factory tach does not work. Wire is plugged into the "tach" connection on the HEI. Any suggestions? Thanks, Dave
  • William C.
    • May 31, 1975
    • 6037
    Re: HEI Distributor Tach Problems
    Factory tach in '70-72 was driven off the distributor mechanically. The hei generally does not provide for this feature.
    Bill Clupper #618
      • 15596
      Originally posted by David Martel (51547)
      Good Morning All,
      I wonder what wire that might be, since 1970 does not have a factory installed wire for the tachometer.
      • Michael W.
        • April 1, 1997
        • 4290
        As Bill stated, the stock tach is mechanically cable driven off the distributor. The standard GM HEI units have no such provision. Your choices are to substitute a later model Corvette tach ('75 and up) or revert to a standard type distributor. Given that the HEI units have no real advantage other than being mtce. free, I'd put the stock distributor back in and forget it.
